12 inch woofer
0 Members and 1 Guest are viewing this topic. Read 1063 times.
Derockster
12 inch woofer
« on: 10 Feb 2021, 12:05 pm »
Can you kindly offer some suggestion for a 12 inch woofer.
frequency range 46 htz to 3400htz Sensitivity 90db or higher
To be used in either ported or sealed box.
will be mated with my Oris horns to cover from 480htz up.
Regards
Derockster
WGH
Re: 12 inch woofer
« Reply #1 on: 10 Feb 2021, 04:18 pm »
A quick check of woofer frequency charts show that 12" woofers usually only go to 1200 Hz and get real rough any higher.
But a couple of custom speaker manufacturers have started using the Satori 9.5" woofer which enables them to crossover to the midrange much higher, with a good crossover design it may go to 3400 Hz.
https://www.madisoundspeakerstore.com/approx-10-woofers/satori-wo24p-4-9.5-egyptian-
Selah Audio Harbinger - Proper driver integration was key here and not a simple task to marry a 9.5” woofer to a 2” dome midrange. In order to make it work the woofer required an extended and well-behaved upper end frequency response.
http://www.selahaudio.com/harbinger
Salk Sound Song3 Encore -  Satori 9.5" woofer, Eton 4" magnesium midrange, beryllium tweeter
https://www.salksound.com/model.php?model=Song3+Encore
Derockster
Re: 12 inch woofer
« Reply #2 on: 11 Feb 2021, 01:40 pm »
gd morning All,
Apologies, that should have been to play from 480htz down and not up.
Regards
Derockster
