0 Members and 1 Guest are viewing this topic. Read 3303 times.
With a 100W amp, you can get well over 100dB SPL! That’s loud, right? Think again....Keep in mind SPL ratings are MAX, as in the very peak where things are at the edge of losing control. This pushes the average way down if you want to handle the dynamics (peaks) accurately as well as quiet sounds.That’s why a 1000W amp can sound so good (as in better than a 100W amp with similar performance characteristics otherwise) playing at low to moderate levels.So, more power doesn’t mean louder average to me, just better dynamic performance.
What can be difficult and possibly expensive is finding an amp that gives you the "magic" at very low levels (with very low noise), but also has the explosive brute strength to handle dynamic swings.
Absolutely!!! I never understood the flea amp crowd who says, "get a high efficiency speaker and a low wattage amp." That's OK in theory, but dynamics will likely suffer. For this reason, I typically buy the highest powered amp with the beefiest power supply I can afford with my 98dB speakers. I recall a few years ago, I was listening to a live performance and the dynamics were through the roof. At that moment, I realized just how delusional me and my audiophile buddies have been in comparing our systems to a live performance. Sure, detail, resolution, clarity, imaging, soundstage, etc., are important, but if it ain't dynamic, it isn't realistic.
I can see someone buying a pair of ZU's, owning a SET amp, and thinking the ZU's will sound great with the SET amp. And then thinking the speakers suck, which is certainly not the case. I didn't realize the ZU's true potential until I hooked them up to Tommy's STM. My God did they jump to life! Then took it a few steps further with his Golden Cherry Monoblocks. I couldn't believe I was listening to the same speaker. The authority and attack the ZU's played with was startling. Even Sean at ZU says that he LOVES high power on his speakers. That pairing his speakers with low powered amps is not taking advantage of his high efficient designs. He has told me that himself and in an interview on YouTube. I think it was either with John Atkinson of Stereophile or Steve Guttenberg, The Audiophiliac. I will post a link to that interview. Sean said you're missing the point of his high efficiency speakers. High and clean power = life, dynamics, attack and immediacy to ZU's. PERIOD. I've experienced it with my own ears.
Sorry I'm asking this in the Digital Amplifier Co. circle, but this thread got my attention and am enjoying the responses. I'm curious to hear anyone's thoughts (even generally speaking) about this topic, but for multi-channel amps. I may be in the market for a 5 channel amp: 4 channels for active bi-amp of main speakers, and 1 channel for an 'ambiance fill' reduced-volume center channel. I realize I could go 2 stereo amps for the mains + a mono for center, but I need to keep things as simple as possible. So some 5 channel amps I'm considering are:ATI NcoreATI 'regular' class A/ABATI fully balanced monsterMonoprice (made by ATI)NAD NcoreBrystonParasound hi-bias, (first 6 watts or so as Class A). Any thoughts or opinions? Is the Parasound hi-bias Class A worth chasing? I've heard that well executed Class D sounds remarkably similar to Class A, but never heard myself..... Does going active reduce my need for higher watts, due to not being wasted in a passive crossover? etc.
