Candela upgrade
0 Members and 1 Guest are viewing this topic. Read 1928 times.
erniek
Candela upgrade
« on: 9 Feb 2021, 02:05 am »
Is there an upgrade path to the Candela besides tubes?
marvda1
  • freelance reviewer: The Sound Advocate
Re: Candela upgrade
« Reply #1 on: 9 Feb 2021, 06:10 am »
Caps, fuses, and internal wire.  what tubes are you using in it?
Charles Calkins
Re: Candela upgrade
« Reply #2 on: 9 Feb 2021, 06:57 am »
  Erniek:
          You better talk to Klaus before you start fooling around with the Candela.
                                                             Charlie
AlTran
Re: Candela upgrade
« Reply #3 on: 9 Feb 2021, 05:51 pm »
You don't talk to Klaus to upgrade your Candela. You talk to me. This is not a joke.
If you call Klaus now, he will tell you to call me.
Hopeful
Re: Candela upgrade
« Reply #4 on: 15 Feb 2021, 09:28 pm »
I would like to know more about this as well.
I own the Candela and would for sure down the road want to upgrade if there is a path to do so.
What are the benefits.  Changes in performance?
What are the upgrades?
erniek
Re: Candela upgrade
« Reply #5 on: 16 Feb 2021, 01:39 am »
What are some things that you suggest AlTran?
Zyphryx
Re: Candela upgrade
« Reply #6 on: 21 Feb 2021, 01:11 pm »
I have the Dialogue preamp going into a pair of Khartago/Kismet monos. I kept reading about how the Focals are so lean on bass but the 948s sound wonderful with this setup and have plenty of bass. Haven't noticed any hissing either.
After about a year I started trying different tubes. So far I've tried the Brimar and Gold Lions but it felt like a lot of detail disappeared. I have Sylvanias in there now and I like those the best. Curious to know how the EVO 400 would sound.
