0 Members and 1 Guest are viewing this topic. Read 2397 times.
Hi. I'd really appreciate views/advice on how to ground a power filter/power strip. I understand the wall outlets in the U.S. & Canada are wired in parallel, while in the UK/Hong Kong a ring circuit is used (I live in Hong Kong). I have also been told that a ring circuit grounds differently than the parallel circuit and, as a result, the ground of a power filter needs to be wired slightly differently to suit. Can anyone explain this further? What should be done differently and why?I did a search on google and came across this diagram of a ring circuit.http://www.bbc.co.uk/scotland/education/bitesize/physics/electricity/household_electricity_rev5.shtmlIt seems that all outlets in a ring are in series. My apartment has several circuit breakers (I per room), and also a residual current device (RCD) that I believe monitors leakage to ground and will trip if the leakage exceeds a certain level (50 mA?). Thanks!- Jay
Jay G'day from Oz (Australia)Once you come out of the wall socket the grounding arrangement within the house wiring doesn't matter to you SO LONG AS YOU POWER YOUR ENTIRE AUDIO ARRANGEMENT from a single wall outlet. Just Wire the Mains filter ground to the wall socket ground pin and the Power Board/ Power Block (That thing with multiple power outlets) ground to the Filter Ground connection. In Oz at least you can buy a Power board with an integral Filter usually for Computer Equipment BUT will work fine for Audio Gear.The situation you want to avoid with ring house wiring is having your Preamp, Power Amps, CD player etc. connected to multiple Wall Outlets since Earth Loops can then occur and you MAY get hum. For those items with just a 2 pin mains plug, ie "Double Insulated" equipment, you can get away with having them powered from a separate outlet since there is no earth connection.Hope this is off help to you,Cheers,Ginger
