Which receiver for music, no HT?
0 Members and 1 Guest are viewing this topic. Read 1259 times.
Otis
« on: 9 Mar 2005, 07:41 pm »
Hi guys, new here after a short lurk  :P  -- I'm looking for a digital receiver and want the best one for 2 ch. background music.
Sources will be 90% tuner, with the rest cd and vinyl.
Any suggestions?
Otis
mcgsxr
« Reply #1 on: 9 Mar 2005, 09:23 pm »
I notice that you mention vinyl as a source - do you own a separate phono preamp?
If not, I am not aware of any digital receivers with a phono section built in... I could be wrong though.
Outside of that, I would recommend one of the JVC receivers, since you will be using analog interconnects - I owned the ES-1 for a while, and understand that for harder to drive speakers, the newer F-10 is the ticket.
What is the rest of your system?
John Ashman
    • http://forum.adnm.com
« Reply #2 on: 9 Mar 2005, 11:32 pm »
See if you can find an NAD C740 receiver, but you may have to call around.  They're recently discontinued and it has their $350 tuner built in, one of the best tuners for the money.  If not the new C720BEE will have a better power section and their $250 tuner in it.
Otis
« Reply #3 on: 10 Mar 2005, 12:34 am »
Guys, yep, I have a separate phono amp, and am running vintage "west coast" speakers, ie JBL L150s, 4333s Pioneer HPM-100's etc. All are 8 ohms.
I guess what I really want to know is among the 'name' digital receivers, JVC, Onkyo, Panny, Pioneer, etc. which if any have worthy tuners and a well-balanced sound?
I've tried the tiny SI amp with a separate tuner, and the lack of dynamics and bass just wore me down. :)
BenF
  • Guest
I recommend the Panasonics
« Reply #4 on: 10 Mar 2005, 01:23 am »
The only receiver line I have seen mentioned with a very listenable tuner is the Panasonics. No other ones get any particular mention. See this thread - it has some very good things to say about the tuner from respected members:
http://www.audiocircle.com/index.php?topic=14922
I have the XR45 and I like the tuner very much. I often record off the FM and burn CDs from the result. I can hear the 19kHz carrier signal (and see it on the spectrum analyzer) so the freq response is pretty wide too.
Based on your particular mix of needs, I recommend you try a Panasonic digital receiver and let it burn-in before deciding on its merits.
Ben
