When is a frequency response curve considered to be flat?
0 Members and 1 Guest are viewing this topic. Read 800 times.
Edgar77
I just (re)watched Danny's video about Open Baffle Basics.
https://youtu.be/7ipMq7KlWwM?t=947
Danny shows different frequency response curves from bad to, what he calls, flat. But they are not really flat. There are still a few dB up and down.
I guess we can't expect +/- 0dB and probably also not +/- 1dB.
When is a frequency response curve considered to be flat? What is "good enough"?
And is it more of a problem when there is i.e. a short 2dB peak? Or is it worse to have 3db difference with smoother up an down?
S Clark
Re: When is a frequency response curve considered to be flat?
« Reply #1 on: 2 Feb 2021, 02:46 am »
+- 3dB is considered a very good curve.  It varies how sensitive we are to slight loudness variation. A 1 or 2 dB rise or fall is not likely to be noticed.
Danny Richie
« Reply #2 on: 5 Feb 2021, 10:24 pm »
Anything in the +/- 2db range is pretty flat. However, a response can be in that range and still have narrow band peaks. And sometimes those can be pretty rough. The real indicator of problems is to look at the spectral decay. Look for a curve with no sudden movements.
