***SOLD*** LKS MH-DA004 dual 9038pro DAC
0 Members and 1 Guest are viewing this topic. Read 613 times.
Early B.
« on: 31 Jan 2021, 06:28 pm »
***SOLD***
For sale is an L.K.S Audio LKS MH-DA004 DAC in great condition. Includes remote. This DAC uses dual Sabre ES9038pro whereby each chip handles the left and right channel audio content independently which greatly enhances the DAC's performance.
One of the sonic benefits of dual chips is the ability to achieve high dynamic range. With an incredibly high dynamic range of 140Db, this LKS DAC can truly depict realism in the music. The sound signature is fluid and slightly warm with a gigantic soundstage and superb accuracy.
Of course, the DAC chip is only a foundation. The most critical is the uncompromising circuit design which includes two high-quality transformers, 13 groups of low-noise regulator circuits, and a well-built power supply.
Price is $595 plus shipping.
Specifications
•   Two-chip ES9038pro decoding method.
•   Two high-quality toroidal transformers, a total of 13 groups of linear power supply.
•   Built-in specially designed Italian Amanero USB module, original license license. USB module added to isolate the chip, you can isolate the computer to the audio system interference signal.
•   Supports USB, I2S / DSD single-ended signal (RJ45), I2S / DSD balanced signal (HDMI), coaxial, BNC, AES / EBU balance, Optical total seven-way source input, all ports support DSD input.
•   Analog audio output port includes standard RCA single-ended output and XLR balanced output pair.
•   Display with VFD display, the display exceptionally outstanding.
•   Use physical key operation.
•   Support 0dB ~ -127dB digital volume adjustment, 0.5dB level. But also has a remote key to skip the volume adjustment function.
•   Support a variety of digital filter mode settings (see user manual). Can be arbitrarily selected, different filter mode, the digital filter attenuation characteristics are different.
•   Supports decoding of internal digital phase-locked loop bandwidth settings (see user's manual for details).
•   Support Deemphasis to increase or turn off.
•   The display has 4 levels of brightness adjustable. Adjusted by remote control.
•   Remote start, standby function.
•   Most of the settings with memory function, turn off the opportunity to automatically save the settings, restart the settings.
•   Dynamic range> 135dB
•   Distortion <0.0002%
•   Stereo resolution> 120dB
•   RCA unbalanced port output amplitude 2Vrms, XLR balanced port output amplitude 5Vrms.
•   Machine size 430 * 320 * 90mm
•   Machine weight 7.0kg
« Last Edit: 1 Feb 2021, 05:35 pm by Early B. »
clelow
Re: FS: LKS MH-DA004 dual 9038pro DAC
« Reply #1 on: 1 Feb 2021, 02:00 pm »
Where are you located? Do you have original boxes for shipping?
Early B.
« Reply #2 on: 1 Feb 2021, 03:34 pm »
I'm in Atlanta and I have the original boxes for shipping.
clelow
« Reply #3 on: 1 Feb 2021, 04:41 pm »
Thanks! PM sent.
