SOLD Furutech e-TP80 Power Conditioner for sale - Mint Condition - $399 - SOLD
0 Members and 1 Guest are viewing this topic. Read 333 times.
Triode Pete
  • www.TriodeWireLabs.com
    • Triode Wire Labs - Affordable Audiophile Cables
SOLD For sale is my personal Furutech e-TP80 power conditioner for Audio & Video. I used it primarily for my Digital Gear, with its dedicated Digital outlets. It is in mint condition, as new. Includes original packaging with owner's manual, Limited Warranty card & QC documentation.
Info: AC Multimode Power Filter and Distributor Rating: AC125V 15A 1875W max. GC-303 EMI-Absorbing Internal Coating plus EMI noise filter.
・2 sets EMI noise filter for each of the two duplex Receptacles.
・GC-303 EMI-Absorbing for each of the four duplex Receptacles.
The four Furutech receptacles in the unit are the FPX-G High-Performance Duplex Receptacle with Gold plating (MSRP -$95 each!) and the power IEC inlet is the FI-06 G AC Inlet with Gold Plating (MSRP - $28).
From Furutech, "The e-TP80 is a sophisticated, luxuriously made power distributor that eliminates many common problems found with audio and video components caused by massively contaminated electrical power.
The AC waveform becomes severely distorted by ground noise, voltage spikes and sags, high frequency power supply noise from other components in your own system,plus radiated high frequency digital noise from processors and digital interconnects.
There are also distortion products at the top and bottom of the AC waveform created by switch-mode power supplies in electronic devices on the same circuit. Additionally, you’re never alone; your residential AC mains supply is shared with other apartments,
homes, and businesses on the same utility transformer. That’s why many audio and video enthusiasts notice their systems are more enjoyable late at night or on weekends!
The beautifully crafted special grade aluminum chassis effectively shields against another common problem, RFI (Radio Frequency Interference), and a layer of Formula GC-303 blocks EMI (Electro Magnetic Interference).
Internal wiring is FURUTECH μ-14 wire(14 AWG) that guarantees low resistance. Furutech Hyper Quality Audio Grade Receptacles are wired to the IEC AC input of the e-TP80. Receptacles feature 24K gold-plated phosphor bronze, non-magnetic conductors for stable, long lasting, optimized power transfer.
・Furutech’s Two-Stage Cryogenic and Demagnetization Alpha Process
The Final Result
The 2-Step Cryogenic and Demagnetizing Alpha Process works in tandem with other design-in features to create the most optimized AC power transfer possible. Furutech’s total awareness and devotion to detail results in a greater sense of power, dynamics, and resolution, with cleaner, blacker backgrounds and a larger, more stable soundstage, vivid tonal colors and deeper extension at both ends of the frequency range. The e-TP80 will allow the delicacy, refinement and nuance of a performance through, along with micro- and macro-dynamics that will leave you breathlessly engaged. Displays of all types will exhibit greater, sharper resolution with less ghosting, color shift, “snow”, or vertical and horizontal lines."
Specifications -
・VOLTAGE         AC 125V 50/60Hz
・FUSE CURRENT 15 A
・LOADING WATT 1875 W
・GROUNDING OUTLET 8 Holes
・OVERLODE PROTECTIVE TYPE         AUTOMATIC CIRCUIT
・INSULATION VOLT         AC 1500V 1 MINUTE 5mA
・LEAKAGE CURRENT         UNDER 1.0mA
・INSULATION RESISTANCE 300MΩ ABOVE DC 500V
・BODY MATERIAL AL. ALLOY PLATE (PAINTED)
・OUTWARD SIZE 400X130X60 mm
・WEIGHT 1.72Kgs
・Formula GC-303
・GC-303 is a special material that Furutech layers and bonds to the interior bottom-plate of the chassis.
 It actually absorbs EMI (Electromagnetic Interference) generated by the internal fittings of the unit.
 The e-TP80 uses no other filtering besides GC-303 so AC resistance is kept to a minimum, allowing a more resolving,
 powerful, dynamic, and colorful performance from your components.
Originally - $820, Yours for $399, including US-domestic shipping. Payment by check (personal is fine), bank wire transfer or PayPal "Friends & Family" (without F&F, the cost will be $419).
Thanks for looking. The pictures below are actual ones, taken today.
Pete
« Last Edit: 31 Jan 2021, 04:16 am by Triode Pete »
