Tidal questions
0 Members and 1 Guest are viewing this topic. Read 950 times.
David C
  • Don't try and lay no boogie woogie on the king
Tidal questions
« on: 29 Jan 2021, 06:15 pm »
I currently use YouTube music on an iPad Pro as a source of music for both my systems. I also use LMS and IPeng to play my FLAC files via a modded Touch on the main system and use IPeng on my iPad to feed my second system via direct connection using the apple lightening connection (the apple plug into the iPad with the simple built in DAC to RCA input into my av/pre.) I would like to stream/play music with a higher resolution Than the YouTube music. How does Tidal fit into this kind of set up?
Sorry if the description may not be enough info to help guide me.
richidoo
Re: Tidal questions
« Reply #1 on: 29 Jan 2021, 06:48 pm »
Hi David!
The tidal app will run on iPad of course, so no problem playing tidal out through your lightning DAC.
Here's a page describing how to log your LMS server into tidal so that it can play tidal stream through your SB Touch.
https://support.tidal.com/hc/en-us/articles/115005871329-Squeezebox
David C
Re: Tidal questions
« Reply #2 on: 31 Jan 2021, 05:20 pm »
Richidoo
Thank you for the advice and link. BTW when i first typed in your “name” spell check on my IPad changed it to...............
Get ready.............................. “rich idol”
Thanks again
