Hello from SpatialKing
0 Members and 1 Guest are viewing this topic. Read 1093 times.
SpatialKing
« on: 27 Jan 2021, 07:57 pm »
I sometimes post on Audiogon as SpatialKing as well.   I no longer work in the audio industry although I did in the past doing design work for preamps and power amps.   Nowadays I work in green energy doing design work with filters, signal processing, and control electronics, all of which is pure analog.  I have two BSEE degrees in engineering, one focuses on analog circuit design and the other focuses on embedded processing.
My equipment mostly Conrad Johnson tubes, Shahinian Diapazions with quad subwoofers.  I have several preamps some of which I bought and some of which are my design.  Recently I started looking at power cable design and line filtering.
