SP3 Dolby Vision - success?
0 Members and 1 Guest are viewing this topic. Read 8037 times.
derekcooper
Re: SP3 Dolby Vision - success?
« Reply #40 on: 19 Apr 2021, 11:31 pm »
*phew* Sounds good - thought I missed something! But ya, you'd spend $1k for some odd reason apparently. No word from Bryston in months now...  :popcorn:
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #41 on: 20 Apr 2021, 12:35 am »
Hi
I think the best person to answer an SP3 question would be [email protected].
james
derekcooper
« Reply #42 on: 20 Apr 2021, 01:31 am »
James - thanks, I'll reach out now.
derekcooper
« Reply #43 on: 20 Apr 2021, 03:10 pm »
As a group update - I spoke with Adam this morning and they are going to investigate.
Of course, the SP3 doesn't officially support DV but hopefully there is a timeline? Will update the group when I have news.
derekcooper
« Reply #44 on: 22 Apr 2021, 12:22 am »
SOLUTION!
So I worked with Adam Tanner and we resolved the issue.
Turns out that you *have* to use the left-most HDMI output from the perspective of looking at the front of the SP3 - that's the one most outboard, furthest from the HDMI inputs.
Obviously it assumes you are using fast HDMI cables - DV needs a lot of bandwidth and *normal* cables won't do the job.
You also *can't* connect a second HDMI cable to the other out port as that will disable DV on the primary.
So, HUGE kudos to Adam for finding the solution. Great job Bryston. We now have a solution and know what prevents it from working.
gbaby
« Reply #45 on: 23 Apr 2021, 07:08 pm »
SOLUTION!
As soon as eARC is available by upgrade, I'm getting the upgrade. I think this will extend the life of the SP3 for at lease another 5 to 7 years.  8)
BSMSPEMBA
« Reply #46 on: 13 Sep 2021, 03:58 am »
Hi James,
Do you know if eARC is available with the latest HDMI board upgrade?
Thank you
« Reply #47 on: 13 Sep 2021, 11:29 am »
Hi James,
Thank you
Sorry I do not - email Adam on that - [email protected]
james
gbaby
« Reply #48 on: 13 Sep 2021, 07:16 pm »
james
James, is Stan still with Bryston?
« Reply #49 on: 13 Sep 2021, 07:37 pm »
Yes but he is away for 2 weeks on holidays.
gbaby
« Reply #50 on: 14 Sep 2021, 02:16 pm »
I am glad Stan is still around. I will never forget what he did for me when I first purchased my SP3. He made me a Bryston customer for life.  8)
BrystonFan
« Reply #51 on: 12 Jul 2022, 10:16 pm »
Hi Everyone,
Any news on upgrades for SP3 ?
