2 questions regarding my future NX-Otica build
0 Members and 1 Guest are viewing this topic. Read 946 times.
RAHKASHI
« on: 10 Jan 2021, 02:17 am »
The first question should be rather easy to answer:
What are the dimensions of the side wings of the NX-Otica? I need them so I can order veneer in the right size.
The second question is about acoustic treatment on the frontwall.
My room is 24,5ft by 18ft. I already have 12 absorption panels on the sidewalls/ceiling (my room is an attic, so the sidewalls pretty much are the ceiling).
Each panel is 1,6ft wide ,3ft long and 4 inches deep.
Since the NX-Oticas are dipole speakers I won't be able to avoid diffusion on my frontwall anymore.
I found 2 options so far, that seemed reasonable:
 1. DIY skyline diffuser
     I used the calculator from this site:
     http://www.mh-audio.nl/Acoustics/DiffusorCalculator.asp?fl=573&fh=4100&calc=Calculate+Diffuser#result
     As the lowest frequency I used 573hz and 4100hz as the highest.
     I plan on building 8 of these panels, 4 behind each speaker.
 2. DIY quadratic diffuser by Acoustic Fields
     The one I planed on building was the DIY version of this one:
     https://www.acousticfields.com/product/sounddiffuser-acousticdiffuser-qd23/
     I was going to build 2 or 4 of these.
     They sell the plans for it in a bundle with some other diffusion panel plans for 49$. It seems like a fair price.
Which diffusers should I choose? Or are there any better DIY options out there?
Thanks in advance for any answers!  :D
Endo2112
  • Particularist
Re: 2 questions regarding my future NX-Otica build
« Reply #1 on: 10 Jan 2021, 08:04 pm »
Jay and I have heard good results with the Pi Audio diffusers behind, and absorbing the first reflection point.
Don
