0 Members and 1 Guest are viewing this topic. Read 5322 times.
A lot of “new” Dac tech comes down to your intended use. If you stream and download very high res music above what the EE can reproduce then upgrade. If you don’t do ultra high rez then do some of the suggested mods and spend the rest on more music. If you purchase a new Dac you will notice a change in sound but is it better? Probably not...just different and is the difference worth the cost?
...From the reviews I've read the Chord Qutest does have some appeal based on reviewer descriptions of the sound, but the price isn't exactly cheap that's for sure.
