Final Sound Electrostat 5.1 system
0 Members and 1 Guest are viewing this topic. Read 656 times.
vitop
« on: 3 Jan 2021, 07:12 pm »
This is a complete Home Theater Electrostatic Speaker 5.1 setup It consists of:
(2) floor standing 600i (Original $6000 pair)
Frequency Response : 45Hz-20kHz  +/- 3dB
Sensitivity:  86dB (2.83 volts at 1 meter)
Impedance: nominal 4 ohm
Amplifier minimum: 75 Watt
Amplifier recommended: 100 Watt
Dimensions: 62.2 x 14.2 x 2 inch (158 x 36 x 5 cm)
Dimensions (electronics housing): 11.4 x 5.5 x 3.1 inch (29 x 14 x 8 cm)
Weight: 46lbs. (21kg)
Mounts: floor Stand (standard)
wall mount (additional cost)
Finish:   satin silver with black (standard)
Feet:     silver top/black rim
Glass/marble (optional)
(1) 600CP (Original $1995)
Frequency Response : 65Hz-22kHz  +/- 3dB
Amplifier minimum: 50 Watt
Amplifier recommended: 75 Watt
Dimensions: 47.6 x 10.8 x 1.6 inch (121 x 27.5 x 4 cm)
Dimensions (electronics housing): 9.6 x 4.3 x 3.5 inch (24.5 x 11 x 9 cm)
Weight: 22lbs. (10kg)
Mounts: set top base (standard)
(2) 300i (Original $1999 pair)
Frequency Response : 95Hz-22kHz  +/- 3dB
Amplifier recommended: 60 Watt
Dimensions: 49.2 x 8.1 x 1 inch (125 x 21 x 2.5 cm)
Dimensions (electronics housing): 7.1 x 8 x 2 inch (18 x 20.3 x 5 cm)
Weight: 17.5lbs. (8kg)
Mounts: floor Stand (standard) wall mount (additional cost)
(1) S80 Subwoofer (Original $695)
Frequency Response : 40Hz-300Hz  +/- 3dB
Crossover Frequency : 40Hz-300Hz
Power Amplifier: 60 Watt
Driver: 6.5in (16.5cm)
Output: Greater than 100db SPL over rated frequency response at 3% THD, peak output 108dB
Dimensions: 10.2 in cube (26 cm cube)
Weight: 28lbs. (12.7kg)
Finish:   Piano Black
I am the original owner of these speakers and have all the boxes.
I have been using all except for the subwoofer. It has never been used and is still new.
They are really great speakers. Electrostats require power as well as speaker hookups. I had a custom power supply made that sat inside my equipment cabinet that had wires going to the speakers along with the speaker wire to provide the power. I will provide that to the buyer also. I have three factory power supplies that are still in the boxes that I will also provide. The two large speakers are floor standing and come with the stands. The two rear speakers have a wall mount. The center speaker was located under my TV with a wall mount and somehow the part that mounts on the wall got lost when we took it off and did some redecorating. It was an aftermarket wall mount that the dealer supplied with it. The part that mounts on the speaker is still there, but the wall mount is not. Something would have to be mounted on the wall or an entirely new mount would be needed
There is nothing at all wrong with either how they look or how they sound. They are large but very thin and so they do not look overwhelming. They needed to pass the wife test before we bought them. I have the manuals for the center and rears. I know I had the manual for the front speakers but lost them. I reprinted it from the internet. I don't think I ever had a manual for the subwoofer. This a great chance to pick up a full set of high end electrostatic speakers at a fraction of their original cost.
There are a lot of very large boxes that weigh a lot so I am listing these as local pick up. Shipping arrangements can be made at buyers expense, but I do not want to be responsible for any damage. Maybe a service like Uship that will pick them up and deliver them directly to a buyer would work.
$2800 for everything
Phil A
Re: Final Sound Electrostat 5.1 system
« Reply #1 on: 3 Jan 2021, 10:37 pm »
"There are a lot of very large boxes that weigh a lot so I am listing these as local pick up."  Did I miss local pick up from a specified place?
vitop
« Reply #2 on: 3 Jan 2021, 11:11 pm »
I guess my location might be somewhat useful!  :duh:
I am in Northern Houston
