Accessory Ground stud on BIT-15
0 Members and 1 Guest are viewing this topic. Read 660 times.
hawkeye99
« on: 2 Jan 2021, 08:54 am »
Can you give me examples of what you would use this for?  :scratch:
  • The Demo is Everything!
    • http://www.bryston.com
Re: Accessory Ground stud on BIT-15
« Reply #1 on: 2 Jan 2021, 12:28 pm »
Hi
On some setups I have found that adding a ground wire from your Turntable to the ground on the back of the BIT reduces hum - experiment and see if it works in your system.
james
