Other Stuff
Archived Manufacturer Circles
Red Wine Audio
Cheap Switch Box (Preamp, sorta)
0 Members and 1 Guest are viewing this topic. Read 3089 times.
miklorsmith
7 Mar 2005, 11:01 pm »
Don't want to clog up your Clari-T with a pre? Check this switchbox out:
http://www.decware.com/newsite/mainmenu.htm
6 inputs, one output, no other circuits, nada. $120, and you're done!
It'd look compatible on the shelf too.
WEEZ
8 Mar 2005, 12:26 am »
Yup! And MAD has a 4in-2out box for a few $ more- but with the second output you could direct your source(s) to the Clari-T on one output and to a recorder or headphone amp on the other (switchable).
WEEZ
The elephant normally IS the room
Reply #2 on:
8 Mar 2005, 12:37 am »
For $100 extra Vinnie is moving the power switch mini-toggle to the front and adding another on the front for input switching and a second set of inputs. A bit cheaper than the Decware and saves a set of interconnects if you only need two inputs.
Other Stuff
Red Wine Audio
