BDP-3 with internal SSD
0 Members and 1 Guest are viewing this topic. Read 1400 times.
Johnney
« on: 30 Dec 2020, 10:49 am »
Plan to install a SSD inside BDP-3. Could anyone share max. Capacity of SSD that can be installed and how to configure SSD before and after installation?
Thank you!
Johnney
Re: BDP-3 with internal SSD
« Reply #1 on: 1 Jan 2021, 03:09 am »
Just ordered Samsung EVO 860 SSD 2TB in SATA III. Should I format it in NTSF or exFAT when it arrives?
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #2 on: 1 Jan 2021, 12:34 pm »
Hi
I would use exFAT
james
Johnney
« Reply #3 on: 8 Jan 2021, 11:19 am »
Thanks! James.
Found AOMEI app could format large SSD in FAT32 format. Does BDP plays ISO file?
« Reply #4 on: 8 Jan 2021, 04:00 pm »
Thanks! James.
Not sure on ISO - will leave that to Chris.
james
Johnney
« Reply #5 on: 16 Jan 2021, 07:29 am »
If I install internal SSD or HDD, will it affect the warranty? Local agent has no ideas which amazed me.
« Reply #6 on: 16 Jan 2021, 11:44 am »
Hi
It will not affect the warranty.
james
Johnney
« Reply #7 on: 16 Jan 2021, 12:13 pm »
Hi James,
Thanks and good to hear that.
