Tidal issues with BDP-1
0 Members and 1 Guest are viewing this topic. Read 972 times.
Tezza009
« on: 30 Dec 2020, 03:33 am »
I am having issues with Tidal streaming on my BDP-1. It plays fine for a while and then starts skipping. The BDP-1 then hangs and needs to be rebooted. Everything else - USB playback, Radio Paradise lossless is fine.
Is anyone else having issues?
Note I am on the latest firmware.
Rocket
Re: Tidal issues with BDP-1
« Reply #1 on: 30 Dec 2020, 12:08 pm »
Hi,
Your doing better than me as i've updated to the latest firmware and I can't even get it to work lol
Cheers Rod
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #2 on: 30 Dec 2020, 12:18 pm »
Hi,
Cheers Rod
HI Folks,
I will leave this one up to Chris to answer.
james
Tezza009
« Reply #3 on: 5 Jan 2021, 04:01 am »
Just adding to this now that Chris is back from a (well deserved) break.
Two firmware versions ago everything worked fine with Tidal on my BDP-1. The firmware release which introduced the new login process had issues which appeared to have been fixed with the latest version. However, Tidal is now unusable. It will play for a while and then will skip songs and hang. At this stage the BDP-1 becomes unresponsive and needs to be restarted.
I am assuming it is an issue with the firmware but it could be my device / network. I also appreciate that the BDP-1 is probably at the limits of what it can reliably do!
Any suggestions?
