Bryston BP26P Phono Section
0 Members and 1 Guest are viewing this topic. Read 613 times.
nbrigido
« on: 23 Dec 2020, 07:32 pm »
I was just able to pickup a Bryston BP26P with the MM phono stage. Everything work amazing, sounds great .
My main question, is there any user adjustable settings for the Phono Section or Updates for the Phono section. The unit seems to be about 2013. I  find that output is fairly low in  comparison to he other  inputs.
Thank you
  • The Demo is Everything!
    • http://www.bryston.com
Re: Bryston BP26P Phono Section
« Reply #1 on: 23 Dec 2020, 08:42 pm »
Hi
There are no adjustments on the MM side.
Generally the output will be lower than the other high level inputs but that will depend a lot on the voltage out from the cartridge.
james
