0 Members and 1 Guest are viewing this topic. Read 3948 times.
Hi Who is Ethan that sells Realtraps? Thanks--Richard--
This weekend, I changed a generic 20 Amp outlet to two 20 Amp, silver-plated cryogenically treated outlets. I also changed my Silver/Copper biwire speaker cable (which, incidentally, was connected incorrectly to my RM40s -- the "high" went to the "low" and vice versa) to cryogenically treated and more expensive single-wired cable. Lastly, I reversed the phase of my speakers. The paperwork that came with my amp said that the amp is inverted phase, so I thought that I should reverse the + and - connection ...
The end result? I think I can tell a bit of difference, but the difference is tiny.
.I'm also going to try a totally blind test with some stuff I'm ordering. I'm going to be blindfolded, then have a helper randomly select cables to put on, then I'll see if I can tell any difference. I do think the new speaker wire has made more of a difference than I initially thought -- the music seems "smoother" and is more listenable...
So, while I have bought expensive wire, I think that given a choice between acoustic products and wire, the former is better than the latter. ...
