Long XLR balanced cables vs Long speaker cables
0 Members and 1 Guest are viewing this topic. Read 1556 times.
almostbuff
« on: 20 Dec 2020, 07:35 pm »
I'm considering using mono amps with my Song 3A's currently on order.  I'm thinking of placing each mono amp next to the speaker with a .05 to 1 meter speaker cable run and use longer 8-10 foot XLR cables  to a Lumin D2.  I read somewhere a while back that longer (more than 3 feet) speaker cables will perform better?  If that is the case then why is it not an issue for active speakers being that the amp(s) is even closer to the drivers.  I can go either way, I just wanted to know which configuration is better.  thanks.
jjss49
Re: Long XLR balanced cables vs Long speaker cables
« Reply #1 on: 20 Dec 2020, 07:38 pm »
long xlr's better, if the circuit is truly balanced
zoom25
« Reply #2 on: 20 Dec 2020, 07:46 pm »
If length is needed, XLR being the longer one to make up the distance is what's preferred.
Here is Empirical Audio's take on it: http://www.empiricalaudio.com/computer-audio/audio-faqs/short-versus-long-cables
As for why minimum length is given for speaker cables...something something Naim and Zobel networks.
I also have 8 foot or more speaker cables in 2 of my passive setups out of necessity. Can't say if it'd sound better or worse, with a very short length of the same cable The others are active with internal amps, so I only have to worry about XLRs.
lokie
« Reply #3 on: 20 Dec 2020, 09:49 pm »
FWIW... I switched from a 5M speaker cable to a 5M interconnect (shielded but not XLR) and couldn't be happier.
Works and sounds great with various preamps including a cheapo Chinese Iphone "booster" with an AUX input.
