Newbie again
0 Members and 1 Guest are viewing this topic. Read 536 times.
Oly84
Newbie again
« on: 20 Dec 2020, 05:23 am »
Greetings All. I have been away from the high end for over 15 years now and am amazed at how much has changed and how much I have to learn and relearn. My last system consisted of a Wadia 15 spinner running to a Z-Systems RDP-1 digital eq that could output the 24/96 signal from my Perpetual Tech upsampler/DAC then to a pair of Cary 805C amps pushing Merlin VSM-SE’s with Harmonic Tech cabling throughput. Currently in the process of building a pair of speakers that will use the Dynaudio Esotar tweeters which I have a NOS pair of, mated with the Scanspeak 8545 midbass drivers which the Merlins used. Plan to push these with a Pass or First Watt and Supratek Cabernet preamp. Looking for feedback from anyone who has experience mating a top tier tube preamp with a solid state amp. I loved my Cary tube amps and would like that sound back with a more physical, dynamic presentation. Looking forward to getting back at it.
To the hunt!
Re: Newbie again
« Reply #1 on: 20 Dec 2020, 05:53 pm »
Welcome  :thumb:
toocool4
Re: Newbie again
« Reply #2 on: 20 Dec 2020, 06:08 pm »
Welcome to AudioCircle Oly84
Phil A
Re: Newbie again
« Reply #3 on: 20 Dec 2020, 08:14 pm »
Welcome!
Otinell
  • Looking to learn
Re: Newbie again
« Reply #4 on: 29 Dec 2020, 02:00 am »
Welcome
Re: Newbie again
« Reply #5 on: 29 Dec 2020, 12:50 pm »
Suggest you do more research before getting into DIY loudspeaker building.  Read Floyd Toole's "Sound Reproduction" 3rd edition to learn how loudspeakers and subwoofers behave in-room.  He recommends shopping for loudspeakers based on spinorama test results and use of 4 evenly spaced subwoofers.  With monitors being a given, recommend looking into active designs (very dynamic) that use wave guides to control dispersion and improve imaging.  Buchardt A500 and Genelec "The Ones" come to mind.  And of course a proper listening room (not small or squarish, well insulated, and hopefully dedicated).
Re: Newbie again
« Reply #6 on: 29 Dec 2020, 10:11 pm »
Greetings & Welcome to AC Oly   :thumb:
