**SOLD**Inakustik Reference Power Station AC-3500P
0 Members and 1 Guest are viewing this topic. Read 728 times.
Big Red Machine
The BEST conditioner I have ever used. No drag on the sound and helps you get to dead quiet. Less than 1 year old.
Six outlets - US version.
Comes with 2 20 amp power cords. Original box and manual.
These are $3000 new, can be purchased from Canada for $2400 US + $50 shipping. Offering it at $1800. I'll ship free to CONUS buyers.
"The Referenz Power Station AC-3500P reliably suppresses all unwanted interference from the power system. The Active Power Distributor implements a highly efficient parallel filter perfectly attuned to the audiophile’s needs. The filter leads off all interference from both the power system and the connected devices themselves without restricting the supply. Add to this the dampened sub chassis that reduces mechanical vibrations of the filter components caused by the 50-Hz grid frequency. In addition, the star-shaped distribution topology ensures uniform supply of all connected units. This way, the Referenz Power Station AC-3500P becomes a key factor to a fine yet powerful sound. The technical design is housed in a stout metal enclosure with a front panel of silver or black anodized brushed aluminum. Six high-quality power sockets are available at the rear panel. The centrally placed high-current power inlet (IEC C20) allows for easy replacement of the supply cable – for example, with a longer one. The built-in surge suppressor protects your precious devices from voltage peaks, and you can conveniently switch all power sockets on and off using the power key on the front panel. An indirect LED light located at the front-panel bottom shows the current operational status: white is for the standby mode while blue indicates that the Power Station is on and the power sockets are active."
« Last Edit: 7 Dec 2020, 11:11 am by Big Red Machine »
screener
Re: Inakustik Reference Power Station AC-3500P
« Reply #1 on: 6 Dec 2020, 11:25 pm »
Pm coming.
