Introduction
0 Members and 1 Guest are viewing this topic. Read 2105 times.
Hopeful
Introduction
« on: 6 Dec 2020, 10:54 pm »
Hello
I am Kevin Meeks
Live in Goshen , Kentucky
I have had issues getting on Audio Circle.  I had to create a new user ID.
I own the:
Kismet Stereo amp (most up to date)
Candela Preamp
Suspiro without external power supply (but have the external power supply on order)
Groneberg Interconnects
Glad to be aboard.
Re: Introduction
« Reply #1 on: 6 Dec 2020, 11:39 pm »
Sorry  for the prob you had, what was your first account name ?
Hopeful
Re: Introduction
« Reply #2 on: 7 Dec 2020, 11:28 pm »
thankfulforyou  (if I remember correctly)
Re: Introduction
« Reply #3 on: 7 Dec 2020, 11:38 pm »
Thanks, the admin will see it.
ServerAdmin
Re: Introduction
« Reply #4 on: 8 Dec 2020, 03:47 am »
There aren't enough similarities in the accounts to merge them, please continue to use this new one.
Hopeful
Re: Introduction
« Reply #5 on: 9 Dec 2020, 01:43 am »
Thank you.
Hopeful
Re: Introduction
« Reply #6 on: 13 Dec 2020, 03:43 pm »
I am not getting any responses to my post.  There are 137 views.  Is there something I need to do on my end?
GentleBender
Re: Introduction
« Reply #7 on: 14 Dec 2020, 12:13 am »
Are you are referring to the Suspiro with and without the separate power supply? Many of us have not had the opportunity to listen to both units. I have the standard version, but have never had the opportunity to hear the upgraded versions.
Hopeful
Re: Introduction
« Reply #8 on: 14 Dec 2020, 02:07 am »
Yes.  Thank you.
