6L6GC/KT88 SE Headphone/Speaker Amp + Power Supply SOLD
0 Members and 1 Guest are viewing this topic. Read 648 times.
tlarwa
Amp and power supply built by Wauwatosa Tube Factory in the Milwaukee area. This design utilizes an overbuilt power supply in a separate chassis, and can accept 6L6GC/6V6/KT88 output tubes. The amp has a toggle to switch between headphone and speaker mode, as well as an ultralinear/triode mode toggle. I have primarily used the amp for powering my 99dB efficient folded OBs, with great success. I have also run 6L6GC and KT88 tubes, and both are included in the sale price. I am completely happy with this amp, but have moved to 45 monoblocks and don't have the need to keep both. The links below give a thorough explanation of the design and build, along with pictures. If you have more specific questions I can go to the builder for more clarification, as i keep in regular contact with him. Both the amp and power supply look great and function perfectly. I'm not 100% sure of the output, but I believe it's 5-7 watts, depending on which mode you are in. By the way, the amp is very quiet, even on my sensitive speakers. No noise issues here at all.
https://imgur.com/a/W4sVe
https://wtfamps.com/la-luciernaga-part-1-the-psu/
https://wtfamps.com/la-luciernaga-part-2-the-amp/
$1000 + actual shipping in the CONUS. I will likely pack them in separate boxes and then place them into one main box for shipping. Overall weight for the amp and power supply is ~30#. I expect shipping will probably cost $50 or so, if I had to guess, but will confirm prior to payment and shipment.
« Last Edit: 11 Dec 2020, 11:31 pm by tlarwa »
