DIMD PP-10 EL84 Integrated Tube Amp
0 Members and 1 Guest are viewing this topic. Read 2086 times.
shawbros3
« on: 5 Dec 2020, 10:28 pm »
DIMD PP-10 EL84 Integrated Tube Amp in excellent condition up for sale (9/10). I took this amp on a trade from an authorized dealer in Canada. Pictures are stock, but I will try to add actual pictures in a few days. If your speakers only require 10 watts then this amp will deliver very liquid and toe tapping sound, bass is very snappy. I played them with Omega 8XRS, Klipsch Cornwalls, and Avantgarde horns and they were dead quiet in all applications.
Asking $2000 ($3200 MSRP)
Shipping and 3% Paypal fees will be quoted after the sale. I'm estimating around $50-75 shipping depending on destination.
I've sold many items on here in the past and on Audiogon under the same username. Buy with confidence!
SPECIFICATIONS:
Operating class: AB
Output topology: Push-Pull, UL
Output tubes: 4 x EL84
Driver tubes: 2 x ECC83
Nominal speaker impedance: 6 or 8 Ohm
Maximum power: 2 x 10 W
Inputs: 4 RCA pairs
Input sensitivity: 420 mV
THD @ 1W (1kHz): < 0.1 %
THD @ 10W (1kHz): < 0.3 %
Frequency response (+0/-0.5 dB): 20 - 20 000 Hz
Power bandwidth (+0/-3.0 dB): 10 – 40 000 Hz
Dynamic range: 90 dB
Stereo crosstalk @ 1W: -65 dB
Output impedance @ 1W: 2.8 Ohm
Global NFB: 6 dB
Mains voltage: 230 VAC / 50 Hz
Power consumption: 100 W
Dimensions: 430 x 159 x 280 mm
Weight: 9 kg
« Last Edit: 6 Dec 2020, 01:20 am by shawbros3 »
richidoo
Re: DIMD PP-10 EL84 Integrated Tube Amp
« Reply #1 on: 6 Dec 2020, 12:58 am »
That looks cool!
Grinnell
« Reply #2 on: 7 Dec 2020, 03:30 pm »
Very elegant
shawbros3
« Reply #3 on: 25 Dec 2020, 12:32 am »
Bump
shawbros3
« Reply #4 on: 1 Apr 2021, 04:09 am »
Bump
tybee
« Reply #5 on: 5 Apr 2021, 05:30 pm »
Recently, I purchased a DIMP-10 EL84 amp from another party after reading the many excellent reviews in Europe regarding how carefully this integrated was designed and constructed.  Having owned many EL 84 amps, this is one of the best that I have experienced and comes very close to an updated Eico HF81 integrated that sounds very SET like compared to an Oliver Sayes 45 Yamamoto clone.  Good luck on your sale,  I am keeping mine.
shawbros3
« Reply #6 on: 27 May 2021, 05:56 pm »
Bump
shawbros3
« Reply #7 on: 16 Aug 2021, 03:56 am »
Bump
