0 Members and 1 Guest are viewing this topic. Read 14424 times.
No. Unfortuneately, as audiophiles, we alter what constitutes proof. We oppine endlessly on the minuitia wrought by this or that components change or burn in phenomona, but rarely follow the simpleist of experimental techniques, maitaining a control sample. Rather, we rely on aural memory, and maitain we can recollect subtle differences over periods spanning months. I'm as guilty as anyone and will simply rationalize by saying, I don't have the resouces (or discipline) to incrementally verify differences c ...
I'll jump in here with my 2 cents. the terms "Break-in" and "Burn-in" should not be interchanged. "Break-in" should refer to mechanical components (E.G. speaker drivers) and "Burn-in" to electronic components (E.G. semiconductors, caps).I learned to break-in drivers years ago, but have no proof that it really works. It seems to work, but I've never heard an A-B test. And in all my years in pro audio, I've rarely heard it mentioned. Pro drivers would seem to need as much or more break-in than ...
......Occam ,I have the same complaint about the Panasonic FM caps when used as a coupling cap.They also take a long time to break in, maybe month depending on use. The good thing is that they smoke a BlackGate from the beginning and just get better. ...
I suspect that there may be a relationship between our brainsauditory perceptual development...how sound is "decoded"by the brain and given a "context" within the field of our experience of what we think of as the real...and our need to"confirm" a condition of constant "contact" with our environment ... would like to add a third consideration. That all of our perceptions are based on COMPARISON... Here is where the devil comes into the picture with regards to our audio junkie habit...we cannot "know" what anything sounds like without some form of comparison...we listen to this or that new component...let us say a speaker...and then we compare it to the one we have been listening to...and that is where and when the "thrill" seeps into our soul...but over time, a sustained diet of this new "thrill" no longer holds our interest...because as soon as it becomes our resident speaker there is nothing to compare it to... What I am suggesting here is that the thrill of each new component is merely based on some form of comparison...without comparison we would have no way of "judging" the "value" of our audio listening experience...except of course if we compare it to live music... but live music has so many variables that it may be impossible to use that as an “absolute”...
Occam,The application is as an output coupling cap in a preamp. Actually the test was rather simple to do, I modified one channel at a time and compared a fully broken in 680mfd 35 v BlackGate NX to a green 560 mfd 35 v Panasonic FM cap. I put a mono signal through both channels and switched between channels. The differences were very obvious with the clear winner being the FM cap. I then proceeded to modify the the other channel.This was a no brainer and at a $0.61 each a very cost effective mod as well. Scotty
When you can believe capacitors can change, why not the insulation on the wires ?
Quote from: AphileEarlyAdopterWhen you can believe capacitors can change, why not the insulation on the wires ?A good point. But I would want to know just how much the dielectric of the insulation can change, and if that change is audible. And is it a change for the better?
On another note off topic to denverdoc, I was wondering how you implemented the recommended notch filter in your system. Were you able to do this electronically or did you use the passive component approach. Here is a link to an interesting study of the BG 75 performance characteristics. http://ldsg.snippets.org/ALSR/dbsindex.html Scotty.
Exactly, this is apples and oranges--electrolytics use an oxide layer microns thick as a dielectric and involve very complex surface layer chemistry, it is no wonder that this can over time behave in a very complicated fashion--just getting an electrode of any type to behave in a stable fashion is not trivial. Now we are comparing this with polymers mm thick, it isn't reasonable to compare the two.John
I have been in this hobby for 10 years and I did not yet believe that digital cables make a difference leave alone the burn-in. But I DID hear for sure the exaggerated bass and highs of the new digital cable, which also implies, that a digital cable can make a difference.So it all depends, on how much experience, you have in 'listening' to various amps/speakers and other tweaks some of which may not have a scientific basis at all. I would like to first get the theoretical possibility agreed upon. The 'a ...
