0 Members and 1 Guest are viewing this topic. Read 14421 times.
There are lots of DIY and mod wizards around these parts. Can anyone offer any measurements quantifying the performance change during burn-in?I suspect that there is some element of auditory tachyphylaxis mixed in as well. Boy do I love that word...
I can't say that I have experience , for electronics or non-mechanical equipment (no physical movement), an audible difference over time for break-in/ burn-in improvement. But for speakers, the movement of the Magneapn 3.6's did change for the better over time....
But a good way to see if burn-in is adible is to do a quick A/B. Have 2 new components and run one over time to burn-in and leave the other in the box, then compare. This seems simple enough and could be revealing but yet have never read where anyone has done this. ...
As a dealer, I do this all the time... That said, I'm not too anal about cable burn-in (asides from silver cable)...a day or two in the Mobie (cable burner) or a week in the system and I'm good with it. But speakers, anything with a lot of capacitors, or balanced components, it takes a lot of time and is a real pain in the neck... Anyways, I thought this original discussion was whether digital amps in particular were in need of prolonged burn-in time (isn't that why this topic is in "Digital Doman Circle"?)...which is why I focused on some of the digital aspects of components in my first response...
denverdoc, would one measurable example be enough?...
I doubt any of us would disagree as to mechanical parts like a car needing some break-in......
Is there any real proof in the burn-in theory with the digital receivers/amplifiers? ...
