X-SLS - First GR build
0 Members and 1 Guest are viewing this topic. Read 2199 times.
Loudspeakerboy
« on: 30 Nov 2020, 12:58 pm »
Well, that was fun!
Our X-SLS project is complete and my wife and I are very pleased with the results. The only modification made was to make the sandbag area in the bottom of the enclosure a couple inches taller in order to get the drivers level with our listening position.  A servo sub is next up.
PS What’s the trick to get images rotated correctly? I tried rotating the images before uploading. Mystery
RolandButcher
Re: X-SLS - First GR build
« Reply #1 on: 30 Nov 2020, 01:00 pm »
Amazing work - congratulations!
AlexH
« Reply #2 on: 30 Nov 2020, 06:25 pm »
 :thumb: Got to love it.
mlundy57
« Reply #3 on: 30 Nov 2020, 06:34 pm »
Well, that was fun!
What I found to work is to save the image in a reduced size, either 50%-80% of full size or to save the full size image for the web, which reduces the file size. Depending on your photo editing software, you may not have an option to "Save for the Web". If that's the case, just save as a JPEG at Medium size (50-80%). Then upload the smaller file. The smaller size file appears right side up in the post. There are probably other ways that will work, I just don't know what they are.
Loudspeakerboy
« Reply #4 on: 30 Nov 2020, 06:39 pm »
I’ll give that a try,
Peter J
  • Hmmmm
« Reply #5 on: 1 Dec 2020, 01:59 am »
Hi Loudspeakerboy. I, and I imagine others, would be curious on some construction details. Sides look like they might be clear over MDF? Paint? Solid wood baffle?
 And I think I see a CNC router as I virtually snoop around your shop. Sorry, I can't help it...
They look great. Nice work.
Loudspeakerboy
« Reply #6 on: 1 Dec 2020, 03:09 am »
Peter,
Yes, the MDF along with everything else is finished bright using Daly’s Profin. The Profin is easy to use and produces a very durable, amber-tinted finish. I’ve been using this finish on wood kitchen countertops for years. The MDF joints must be tight to pull this off. It ends up looking a lot like fine grain leather. (Be aware that the used wiping rags can spontaneously combust). The front baffles are bookmatched figured sapele. They are an 1-1/8” thick. Because the front baffles are 3/8” thicker than spec I put a 5/8” round-over on the woofer opening and 3/8” on the tweeter. The tweeter round-over probably wasn’t necessary but I was there, and yes, that is a cnc router in the background.
Cheers, Michael
hawkeyejw
« Reply #7 on: 1 Dec 2020, 12:29 pm »
Wow beautiful work.
Danny Richie
« Reply #8 on: 2 Dec 2020, 02:51 pm »
Wow, nicely done.
You're assembled crossovers look great too.
Hobbsmeerkat
« Reply #9 on: 2 Dec 2020, 03:11 pm »
These are gorgeous! Excellent work!
Loudspeakerboy
« Reply #10 on: 2 Dec 2020, 03:50 pm »
Wow, nicely done.
Thanks Danny,
The videos you have been making are very helpful!
Keep up the great work!
Michael
Loudspeakerboy
« Reply #11 on: 2 Dec 2020, 03:53 pm »
Thanks everybody,
Now to pick a new amp.
Cheers, Michael
russellberg
« Reply #12 on: 3 Dec 2020, 04:28 am »
In your third picture it looks as though you have cut biscuit joints in the sapele?  Am I seeing that right?  Just wondering about your construction methods.  I did a similar version of the X-SLS's where I clad the whole MDF box in quilted maple.  If you are interested... https://www.audiocircle.com/index.php?topic=171848.0   Great build!  Love the SLS's.
Loudspeakerboy
« Reply #13 on: 3 Dec 2020, 12:12 pm »
Nice looking cabinets Russell,
Yes I used biscuits to help index the front baffle during final glue-up. Biscuits are pretty much worthless for anything other than basic part indexing.
Cheers, M
