Herbie's Donut Mat, Turntable Mat-New
0 Members and 1 Guest are viewing this topic. Read 375 times.
jhrlrd
« on: 28 Nov 2020, 11:16 pm »
New and unused, 2 available.
From his website:
Firm elastomer "donut" is a great record/platter interface for Raven AC, Verdier Platine, and other turntables that typically do not use a platter mat. Standard .81mm-thick mat has sufficient body/weight that it stays in position on the platter and records lift right off. Herbie's Donut is also handy to use instead of awkward-to-use shims and to avoid adjusting VTA between records: just place on top of your present mat when you need a height boost for thin records, take it off for use with thick records.
$32.95 retail, asking $25 each shipped
