Synergistic Research 1.5m Galileo UEF XLR w/ Blue Fuse Treatment and SX Bullets
0 Members and 1 Guest are viewing this topic. Read 374 times.
mikeg1
Original owner and mint. Installed and moved only for Blue Fuse treatment upgrade . 1.5m XLR interconnect pair with box. Blue treatment found in SX ($800 value) and upgraded SX UEF tuning bullets. Essentially these are Galileo SX interconnects. Shipping included. $4995 ($10,500 retail).  Please add 3% for PayPal. See my audiogon feedback under mikeg. Love SR products. Changed amplifiers and the new amplifier only has single ended input. Replacing with SR single ended RCA interconnects. Hence the sale.
Many excellent reviews and winner of Stereotimes Component of the Decade.
Built from (4) handmade 99.9999% Pure Silver and Graphene Air String geometries and UEF Graphene Shielding in parallel with (2) 4th Generation Tricon Silver Matrix geometries with UEF Graphene Shielding for a total of 12 cables in a single pair of Galileo UEF XLR interconnects. Each individual geometry is sheathed to cancel vibration without resorting to excessive dampening which can compress sound. All (6) UEF Graphene Shields are tied to our Ground Plane Technology which passes static electricity and noise picked up by the shields direct to ground, and not your components for music that is true to the source without distortion.
To maximize musicality we developed a complex Multi-Layer UEF Inductive Cell made from Pure Silver foil and Graphene with a Japanese Silk Dielectric selected in blind listening tests for the organic sound of silk imparts when used as a dielectric. Lastly, we developed two very special UEF Tuning Modules expressly for Galileo UEF cables that change the vibrational characteristics of the cable at the signal or electron level. The Gold UEF Tuning Module imparts a warmer more layered balance to your music while the Silver UEF Tuning Module with its faster vibrational characteristics transmits the maximum information while still sounding musical. The choice between Gold, Silver or none is yours to make, and when you do, you’ve voiced your cables to match your system and personal preference.
Each pair of Galileo UEF Interconnects incorporate two UEF Carbon Fiber cylinders. Inside each cylinder is a UEF Cell comprised of pure 99.9999% Pure Silver foils and Graphene conductors with Teflon and Japanese Silk dielectrics. This Patent Pending technology is applied direct to signal, shields and ground to lower your system’s noise floor allowing your music to reach you unimpeded and without distortion. The result is music so natural you’ll swear you’re at the live recorded venue.
Lastly, this interconnect received the same conditioning process they developed for SR Blue Fuses and this increases their musicality as well as shortens their break-in time so you spend more time listening to music, not waiting for your cables to burn-in. And of course, SR hits each Galileo UEF interconnect with 1,000,000 volts of electricity on the big Tesla Coil with a new sweeping frequency pattern that dramatically improves how the signal propagates for the most efficient signal transfer.
"...This set replaced the Wireworld Platinum Eclipse 8 used between my Accuphase Pre-amp and amp. Right away you can tell something special has happened, as if you've sonic-ally climbed a hill and are now above the fog you used to be under. Much greater transparency allows fine details to emerge from a deep black backdrop. They are abundant in rich harmonics, as if all the instruments have been fleshed out and seem more real and three dimentional with a true to life, you-are -there experience that's somewhat lacking in the Wireworld. These are expensive cables but like climbing Mnt. Everest they're a once in a life-time experience that will increase and broaden your love for recorded music. My advise is just do it and be happy for a long time..."
REVIEWS:
Howard Kneller of SoundStage UltraSound (April 2019) wrote:
"...the Galileo SXes may well set a new high bar for audio-cable performance. Further, while at first glance their geometries are more similar to than different from those of the Galileo UEFs, the SXes considerably outperformed the older cables... I’m smitten with the sound of Synergistic Research’s Galileo SXes: breathtakingly lively, exciting, and dynamic, yet gorgeously rich, musical, and accurately full-bodied. They are definite contenders for the designation 'the state of the art'..."
