0 Members and 1 Guest are viewing this topic. Read 3991 times.
If you have a handy experiencied tech ablê tô repair it could worth tô keep, this amp have a lot of parts in a small chassis, not easy tô repair it.
Huh? My unit is not damaged. I'm asking for feedback on mods to the Almarro and what mods are most beneficial and such....
Not meaning to hijack your thread but would you mind sharing what changes have you noticed with the mods and what mods have been most beneficial? What % improvement would you put on each change if forced to do so? I have a base model and trying to decide to sell or mod.
The biggest improvement I noticed on mine was when I removed the volume pot, signal switch and computer-quality wiring from the signal path. Next was changing out the coupling and output caps for Miflex copper, and last was changing the RCA connectors for WBT and the binding posts for Furutech. Overall it took a pretty good sounding amp to an outstanding sounding amp.
Keep an eye on those Jupiters. I had a pair in my Almarro and they melted. Switched over to Miflex copper caps and no problems since.
Thanks Tyson. Agreed, it's pretty good sounding now...appreciate the feedback. I got mine for a screaming deal and it feels like a good hobby. Any resources or threads related to the mods that you could share?
Thanks Tyson! This was a concern I had before getting the Jupiters. One reason for considering the Russian FT-3 teflon capacitors was the thermal stability. Can you say which ones (0.47 or 0.22 uF) melted and what symptoms you noticed?
