SOLD - Alan Eaton 45 Stereo Tube Amplifier
0 Members and 1 Guest are viewing this topic. Read 1581 times.
jwr159
« on: 24 Nov 2020, 01:53 pm »
Asking Price:   USD $1100.00
Payment method:   Paypal
Shipping weight:   30.00 (lbs), will ship in two boxes (a) amp and (b) cage and tubes
Condition:    9 - Excellent - looks new, no scratches or other markings.
I have thoroughly enjoyed this amplifier. it got me hooked on tube amplification. Among the cleanest, clearest sounding amplifiers I've ever heard. I am replacing only with a significantly more expensive 300B amp that is better but not by much. The value proposition of this amp by Alan is off the charts.
Alan is very highly regarded for his impeccable build quality and pure, minimalist design. This amp has been checked out by a skilled tech. The tape on the knob on the back of the chassis is for the lowest noise position
I will include NOS TungSol USA 45 tubes (2), NOS Sylvania 6NS7 tubes (2 - $100 each), 6AX5 rectifier tube (1). The Sylvania 6NS7s are a significant sonic upgrade from the GE tubes included in my purchase originally.
Buyer pays actual shipping and PayPal fees.
Will ship in two boxes, one including the amp. The second the cage and tubes.
Alan's 45 amps have become well known from the Glow in the Dark review. If interested, worth reading.
http://www.glowinthedarkaudio.com/alan-eaton-se45.html
Finally, here is the description from Alan Eaton for similar on his ebay ads (copied and pasted)
"This hand-built stereo amplifier features a deluxe Tamura power transformer. The heavy-duty studio grade Tamura power transformer will run all day and not get hot. It is a commercial broadcast-grade transformer. These are not made today and are from the 1960’s. No transformer built today can match this quality.
Chassis size is 14" x 10 X 3"
Bud brand heavy chassis to better support the transformers
ElectroCube audio grade Mylar capacitors
Point to point hand wiring, with no circuit boards that are difficult to repair and often go bad. If other sellers do not show under the chassis it may be because they use overseas circuit boards. If they do not show under the amplifier, then it may be run using overseas circuit boards.
two gain controls -- one for left and one for the right hand. These are Alpha professional brand studio audio gain controls. With one for each channel, you can use them as a balance control only better. As you do not need a preamplifier to accomplish this function.
Top of the line Tamura brand power transformer -- The Tamura power transformer in this amplifier is a 1960 vintage. It has a large heavy copper band (see last picture) shield around the windings to eliminate hum. It is one of the best power transformers ever made. If they were to reproduce a transformer of this quality today, the cost would be no less than 300.00. Many power transformers just meet the minimum amperage requirement so they get very hot. Not with this Tamura transformer it is a commercial-grade unit and can run all day and just get warm.
Superior 3-way speaker connector, that will not break or come loose.
Solid copper buss bar ground strap wire.
High voltage US Military-grade surplus Amphenol tube sockets, that will last forever. Not the ones from China that fall apart with normal use.
Hammond brand 2.5 volt filament transformer. Not Chinese transformers that are low quality.
« Last Edit: 26 Nov 2020, 02:46 pm by jwr159 »
