FRITZ CARBON 7 SE Mk 2 REDUCED!!! $1500 SOLD!
0 Members and 1 Guest are viewing this topic. Read 1716 times.
djverne
« on: 19 Nov 2020, 05:48 pm »
For sale: FRITZ CARBON 7 SE Mk 2 REDUCED!! $1500 SOLD!
I had the original Carbon 7 and this version has a more detailed midrange and high-end extension. Every type of music sounds wonderful on these speakers regardless of what type of amp is used; low watt to high watt, $40 -$4000, it all sounds wonderful. This speaker has detail, imaging, speed, extension, and is liquid smooth. One of the Best stand mount for electronic music I have used.
Feel free to ask any questions: I have owned the Carbon 7, Fritz Rev 5, Carrera Be, and this CARBON 7 SE Mk 2. Both the Carrera Be and this CARBON 7 SE Mk 2 ran away from the Dynaudio Special 40 in a head to head match up.
New SE Mk 2 version uses an upgraded lighter
& faster ScanSpeak mid/bass driver with more midrange
detail and a wide Dispersion Textile dome tweeter
2 Way vented stand mounted monitor
Frequency Response:
38Hz-35Khz +/- 3 db
Impedance:
8 Ohms nominal @ 1000 kHz- Very easy load on any amplifier including low powered tube amps. See Impedance & fantastic phase curves below
Sensitivity:
88 db (1 Watt, 2.83 V @ 1 Meter)
Bass/Midrange Driver:
7" Carbon Graphite Fiber/Paper Pulp composite cone with non-resonant low loss butyl rubber surround & Kapton voice coil former & die cast frame with massive magnet, bass reflex loaded- rear port.
This unit is an improved version of the highly praised 18W/8545-00 midwoofer, where a new aluminum chassis, an updated cone and a new spider as well as a few other details are introduced, these updates improves mechanical stability and sound performance.
High-quality magnet system design with patented Symmetric Drive (SD-1) continues to be a key feature. The magnet system is the new SD-1 system which eliminates modulation and dynamic distortion, as well as clipping distortion created as it exceeds its maximum linear excursion.
Tweeter:
1" ScanSpeak Textile Diaphragm wide surround Dome tweeter
Wide Dispersion
Extended Frequency to Above 40KHz
Low Distortion
Double magnet with Rear Chamber
Crossover:
Series crossover without any capacitors or resistors in the circuit with the tweeter. Acoustic Reality Series Crossovers
Dimensions/Weight:
16H x 9W x 12D, 32 lbs (each)
Recommended Power:
30 - 150 Watts RMS, without clipping
« Last Edit: 28 Nov 2020, 12:50 pm by djverne »
rollo
  • Rollo Audio Consulting -
Re: FRITZ CARBON 7 SE Mk 2 Carbon Grey $1700 or make an offer
« Reply #1 on: 19 Nov 2020, 08:47 pm »
  Great speaker and at this price someone jump on this. Very linear sound.
charles
djverne
« Reply #2 on: 19 Nov 2020, 08:57 pm »
Yea they have been a pleasure.
