Industry Circles
Bryston Limited
how to connect a speaker to 7b st
0 Members and 1 Guest are viewing this topic. Read 797 times.
avne3
14 Nov 2020, 02:27 pm »
hello
i have 2 7b st amps
i want to connect them to 1 speaker 4 ohm each
attached a photo of the connection
would like some help with that
thank you
Facilitator
The Demo is Everything!
Re: how to connect a speaker to 7b st
14 Nov 2020, 02:45 pm »
Hi
Do not see a photo?
avne3
Reply #2 on:
14 Nov 2020, 02:51 pm »
Facilitator
Reply #3 on:
14 Nov 2020, 03:59 pm »
OK use the two RED connections for Series and make sure you get Positive and Negative red connectors correct on both amplifiers.
james
Industry Circles
Bryston Limited
