Newbie
0 Members and 1 Guest are viewing this topic. Read 474 times.
vutd
Newbie
« on: 7 Nov 2020, 10:22 pm »
Hi everyone,
Newbie here.  I just added a pair of single ended 45 mono tube amplifiers to my system and searching for a pair of high efficiency speakers to pair with the amps.  All my speakers' efficiency range are from 86db to 89db.  So I am here to get help.
Re: Newbie
« Reply #1 on: 8 Nov 2020, 03:04 am »
Welcome  :thumb:
I would suggest you the new Lii F15 FR driver a bargair at $399, you can use it OB as Decware:
https://www.decware.com/newsite/ZMS.html
or you can use the 290L BR box they suggest in his site for more bass:
https://www.lii-audio.com/product/recommended-15-full-range-speaker-driver-for-music-loudspeaker-with-tube-amplifier-f-15-in-pair/
If you need the status of a famous commercial brand in your room you would go for a less musical fidelity speaker with a xover, as a two way speaker from Klipsch (or other brand you like) RF-83(used) or RF-7, avoid three ways speakers at any cost, dont walk run from that.
Good luck
« Last Edit: 10 Nov 2020, 04:21 am by FullRangeMan »
Re: Newbie
« Reply #2 on: 8 Nov 2020, 12:58 pm »
Welcome!
There is no perfect loudspeaker, period.  45 based amps are sweet. The main problem is their very low output.
The challenge with high efficiency loudspeakers I've found is that they typically lack lower bass but do add various colorations (forward, nasal midrange is common).  Crossovers suck power, yet single driver designs almost uniformly lack lower bass.  Large extended range drivers are more efficient but the prevailing whizzer cones are simply mechanical crossovers.   Yet without a whizzer cone larger drivers will "beam" higher frequencies.
Klipsch are quite efficient and traditionally (their classic models) are voiced for tubes, but their efficiency is over-rated, lack deep bass, and frankly can't compete sonically with modern designs.  Even large reinvented classic designs sound better if fed more than a couple of watts as the amp can provide a commanding grip on the driver(s).  Decades ago flabby tube bass was paired with such bass weak loudspeakers to achieve a synergistic mix, but that is just overlapping two colorations, which makes everything sound like those colorations.
Once upon a time tried to warm up to small tube amps, but being a "speaker guy" never could find an acceptable loudspeaker to match up.  So I bailed out of small tube amps.  Your best option may be to look for medium sized, as efficient as possible, extended range driver loudspeakers and add subwoofers.  Floyd Toole and other noteworthy acousticians suggest multiple subwoofers carefully placed around the room to tame inherent in-room bass peaks/dips anyway.
Re: Newbie
« Reply #3 on: 8 Nov 2020, 02:58 pm »
Greetings & Welcome to AC vutd    :thumb:
Phil A
Re: Newbie
« Reply #4 on: 8 Nov 2020, 03:07 pm »
Welcome!
jjss49
Re: Newbie
« Reply #5 on: 9 Nov 2020, 05:44 am »
Hi everyone,
zu's are very nice for not too much money
you should speak about your budget
