Greetings - Happy To Be Here
0 Members and 1 Guest are viewing this topic. Read 552 times.
wdlvwdlv
« on: 3 Nov 2020, 05:17 pm »
Hello,
Glad to make everyone's acquaintance, looking forward to all the great posts and conversations.
My current gear consists of:
Pioneer Elite VSX-32
Pro-Ject 2Xperience sb
Schiit Mani
Klipsch XF-48 Floorstanding Speakers (Active)
Klipsch SW-308 Subwoofer (Active)
I am looking at possibly getting a tube preamp in the immediate future.
Walt
Re: Greetings - Happy To Be Here
« Reply #1 on: 4 Nov 2020, 04:48 am »
Welcome Walt  :thumb:
If you are in USA seems this your best choice for a pre-amp IMO:
http://www.glowinthedarkaudio.com/ux201a.html
Near impossible to get used, so you will have to order direct to Radu at simplepleasuretubeampsrct at gmail.com
Good luck.
« Reply #2 on: 4 Nov 2020, 03:45 pm »
Greetings & Welcome to AC Walt   :thumb:
wdlvwdlv
« Reply #3 on: 4 Nov 2020, 04:04 pm »
Thank you, yes I am in the USA. I did look at the post but do not see pricing, hopefully it's in my range. I do appreciate the suggestion and will follow-up with the vendor.
Phil A
« Reply #4 on: 4 Nov 2020, 04:18 pm »
Welcome!
« Reply #5 on: 6 Nov 2020, 03:58 am »
Just look at the Radu site but failed to see this pre-amp listed.
If you like to add a pre-amp before your power amp to embellish the sound it worth the expanse, but it not necessary with the 2V outputs from the CD standard since your power amps have a volume pot.
