Link for Triple W Sub Enclosure?
0 Members and 1 Guest are viewing this topic. Read 967 times.
zenfishbike
« on: 2 Nov 2020, 01:45 pm »
Hello, I see the dual W enclosure plans on Danny's site but I'm looking for the triple. The two baffles on the dual have differing lengths and driver placement. Rather than me trying to design the 3rd baffle and final cabinet height I'm hoping the plans exist. Plus Danny mentioned in a video that the W needs double thickness sides for stiffness. Even the dual plans don't show that. Would be much obliged if anyone can share a link. Thanks!
zenfishbike
Re: Link for Triple W Sub Enclosure?
« Reply #1 on: 6 Nov 2020, 02:50 pm »
Fyi to close the loop on this question Danny says no plans for a triple W have been drawn up
« Reply #2 on: 7 Nov 2020, 04:56 pm »
If you  are doing  w-frames,   make sure you  add a brace  in  the  "open"  area of the  w....  be sure you  plan  for driver installation as   the brace may cause issue  if you  don't  postioin it correctly.   The  h-frames are less prone to resonence.
You  can beef things up too...   oour h-frames  use   1" for  baffles  and   braces   while the side panles/tops and bases  use  solid  1.5"
jay
