OFC 16ga polyethylene wire and good soldier
0 Members and 1 Guest are viewing this topic. Read 842 times.
KevinTernes
« on: 1 Nov 2020, 06:40 pm »
Hello, New guy here.
I just completed Danny's Klipsch RP600M upgrade kit.  Easy peasy!
I've done plenty of soldering before.  But using the wire and soldier in this kit seemed to be a lot easier than what I am used to.  I usually use the stranded whatever wire that I get at Walmart and whatever soldier.
q1: Where can a guy buy this flexible OFC 16ga non-stranded polyethylene wire and "good" soldier?
All searches seem to return stranded wire.
q2: Is there something different about this soldier?  If so, where can I buy it?
mlundy57
Re: OFC 16ga polyethylene wire and good soldier
« Reply #1 on: 3 Nov 2020, 08:14 pm »
You can order the wire directly from Danny. I use Cardas quadeutetic solder. You can order this online. I get mine from Douglas Connections. They are in Austin, TX
Barryg443
« Reply #2 on: 3 Nov 2020, 10:06 pm »
I’ve been using Douglass Connection for years, last cables I made were from him.  I use KappZapp 7 solder.  Danny is probably best source for wire!
Barry
srb
Re: OFC 16ga polyethylene wire and good solder
« Reply #3 on: 3 Nov 2020, 10:13 pm »
Soldier on!   ;)
Toecutter
« Reply #4 on: 3 Nov 2020, 10:24 pm »
Should  solder matter? Its the conductors contacting  eachother  that matters solder just holds it in place.
