0 Members and 1 Guest are viewing this topic. Read 1052 times.
veloceleste
« on: 24 Oct 2020, 07:13 pm »
« Last Edit: 21 Aug 2023, 06:10 pm by veloceleste »
servingko
Re: B135sst2 preamp out into 3B3 question
« Reply #1 on: 24 Oct 2020, 09:39 pm »
The 135 cubes has the Salomie circuit is in the input stage of the amplification.  The pre amp of the 135 cubed is the same as a B17 and not the B17 cubed, although most of the preamp section is the same.  I am running a B135 cubed with a 3B3 and it sounds great.  I will say that my SP3 with the cubed amps sounds a bit better.
alexone
« Reply #2 on: 25 Oct 2020, 04:31 am »
...does the digital input of the B135² accept 192/24 ???
thanks,
al.
servingko
« Reply #3 on: 25 Oct 2020, 04:55 am »
Yes, the SPDIF coax does, not sure on the toslink.  This was a running change on the later versions.  I don’t know the serial number of B135 cubed unit that first received the newer board but perhaps James can provide that information from engineering.
alexone
« Reply #4 on: 25 Oct 2020, 05:05 am »
...thanks, Servingko...but i was asking about the 135 Squared not Cubed.
but if the 135 Squared should accept 192/24 as well it would be great :thumb:
al.
veloceleste
« Reply #5 on: 25 Oct 2020, 12:37 pm »
« Last Edit: 21 Aug 2023, 06:11 pm by veloceleste »
servingko
« Reply #6 on: 25 Oct 2020, 04:08 pm »
Sorry, I obviously had B135 cubed on my mind.   I had a B100 and a B135 squared for a while.  The squared and cubed 135’s effectively share the same preamp section (BP17) which to me were an improvement over the B100 (BP16) to my ears.  The B17 cubed, while similar to the preamp portion of he 135’s, is a much more versatile preamp.
veloceleste
« Reply #7 on: 25 Oct 2020, 05:40 pm »
« Last Edit: 21 Aug 2023, 06:12 pm by veloceleste »
