Anyone try a JVC RX-DV3SL?
0 Members and 1 Guest are viewing this topic. Read 1031 times.
Johnnyo
« on: 4 Mar 2005, 07:29 pm »
Due to space issues I'm considering one of these units and wondered if it was essentially the digital drives from an RX F10 and a dvd player built into the same chassis.  Any feedback would be greatly appreciated.
Mudjock
    • Sehlin Sound Solutions
« Reply #1 on: 4 Mar 2005, 10:31 pm »
I don't think they are similar....   I own the RX-ES1SL and the RX-DV31SL.  The 31 is handy to have around with the built-in DVD player - but sounds nothing like the Hybrid Feedback amps in the ES1 or the F10.  I think it is fine for a simple, high SAF, low $ home theater system - which is how I finally decided to use mine.
Feisal K
    • DVD-A registry
« Reply #2 on: 5 Mar 2005, 10:06 am »
John
If i had a space constraint, I'd look at the TEAC legacy 700 - this is the small-footprint DVD receivr unit which can  be connected to the highly regarded L700 3 channel poweramp. I believe the DVD receiver sports the Tripath amp as well
