LGK alternate cabinet shapes?
0 Members and 1 Guest are viewing this topic. Read 1716 times.
RonP
« on: 23 Oct 2020, 01:55 pm »
Hey Danny,
do you have any other cabinet designs that would put a single pair of LGKs into a stereo arrangement (in 1 cabinet)? I'm looking to replace my Sonos Play 3's.
(ignore the center tweeter)
Something more shaped like that? (probably will be larger of course)
thanks!
Hobbsmeerkat
Re: LGK alternate cabinet shapes?
« Reply #1 on: 23 Oct 2020, 02:48 pm »
Could always build a pair of LGKs laid flat with the base of one working as the divider for both models?
RonP
« Reply #2 on: 23 Oct 2020, 03:28 pm »
That's REALLY wide.. if I understand what your saying
Like a Flat 5 with only 2 drivers???
https://www.gr-research.com/store/p17/Flat_5.html
Hobbsmeerkat
« Reply #3 on: 23 Oct 2020, 03:41 pm »
I think it would be a little smaller than the Skinny 5, but the same basic shape. I guess it depends on how/where it would be set up?
Danny Richie
    • http://www.gr-research.com
« Reply #4 on: 24 Oct 2020, 03:47 pm »
A small one could be made with only one driver playing full range.
If I then had version made that was more of a lower frequency woofer and in a 16 ohm configuration that I could flank it on each side with that with them and they could cover the lower end.
RonP
« Reply #5 on: 24 Oct 2020, 04:23 pm »
Well I was planning to connect them to one of these:
https://www.hifiberry.com/shop/boards/hifiberry-amp2/
So my initial thought was 2 speakers. I'm not sure how will bridging to channels into one would work? But whatever you think will work.
thanks
RonP
« Reply #6 on: 21 Jan 2022, 07:04 pm »
While you are investigating cabinets.. please create a lil stereo cabinet for 2 LGK drivers.... One LGK for left channel, one LGK for right in the same cabinet.
(I suspect it'll be wider that this ala the skinny series)
Ethan Macfarlane
« Reply #7 on: 24 Jan 2022, 12:45 pm »
Yeh I considered something very similar to this before with build in chip amp. Would be the world's best portable speaker.
