WTB - Shuguang WE6SN7 PLUS Vacuum Tubes - Still looking.
0 Members and 1 Guest are viewing this topic. Read 1209 times.
screener
Looking for a pair.
Used or new.
Thanks, Kim
« Last Edit: 27 Oct 2020, 02:58 pm by screener »
HT cOz
Re: WTB - Shuguang WE6SN7 PLUS Vacuum Tubes
« Reply #1 on: 21 Oct 2020, 06:56 pm »
I couldn't find the WE6SN7 plus and ended up with these for $200.  I no longer need them and if you are interested, I will give you a good deal.
jjss49
« Reply #2 on: 21 Oct 2020, 09:15 pm »
i believe cv181 runs at a higher filament voltage than the we6sn7, so check your particular piece for compatibility...
mresseguie
« Reply #3 on: 22 Oct 2020, 01:14 am »
I've got both WE6SN7 Plus and the Pavanes in my Don Sachs Model 2 as supplied by Don. I think screener has a DS Model 2 as well, so he ought to be fine.
jjss49
« Reply #4 on: 22 Oct 2020, 03:13 pm »
yes don says if his preamp is the version with the black metal insert in the top of the unit, it can run cv181 higher voltage tubes
screener
Re: WTB - Shuguang WE6SN7 PLUS Vacuum Tubes - Still looking.
« Reply #5 on: 27 Oct 2020, 03:00 pm »
Still looking for a pair.
Kim
carusoracer
« Reply #6 on: 31 Oct 2020, 03:19 am »
Very nice. Which ones do you prefer?
