Dsp Crossover
0 Members and 1 Guest are viewing this topic. Read 861 times.
slugworth
Dsp Crossover
« on: 20 Oct 2020, 06:38 pm »
Does the dsp crossovers in an active speaker override the parameters I would use in roon. For example, sample rate, equalization, minimum/linear phase etc.. This is assuming I’m using the speaker’s digital input.
Vincent Kars
  • The Well Tempered Computer
Re: Dsp Crossover
« Reply #1 on: 21 Oct 2020, 09:21 am »
Most of the time the DSP inside runs at a fixed rate.
In the past often 44.1, today often 96 kHz.
This means the audio will be resampled if <> 96
Likewise there will be a DAC per channel inside with its filters, etc.
DSP like EQ, volume, etc. will of course remain unaltered as this affects the bits send to the active speaker.
BTW: this is pretty much like a stand-alone DAC
Unless NOS, DAC run at a different sample rate (upsampling/oversampling) compared with the audio, have filters, etc.
slugworth
Re: Dsp Crossover
« Reply #2 on: 21 Oct 2020, 12:54 pm »
Thank you for the clarification.
