A370PEQ with 2 SW
0 Members and 1 Guest are viewing this topic. Read 986 times.
jrosa64
A370PEQ with 2 SW
« on: 20 Oct 2020, 02:39 pm »
I have the A370PEQ with 2 SW12-8 drivers in a sealed cabinet for about 10 years and it's still going strong and sounding beautifully.
But planning ahead in case the Amp fails, which new plate can I use? Can I use 1 plate with 1 SW or 1 plate with both SW.
Thanks in advanced for your help.
mlundy57
Re: A370PEQ with 2 SW
« Reply #1 on: 20 Oct 2020, 04:17 pm »
The A370 amps are designed for a 4ohm load so you can use 1 of any of the A370 models (PEQ, PEQ3, XLR2, XLR3) with both 8ohm drivers as long as they are both in the same cabinet.
HAL
« Reply #2 on: 20 Oct 2020, 06:45 pm »
You could use a standard sub plate amp, but be aware that the sub will not sound the same at all.
The A370PEQ's servo control changes the driver characteristics in that box.
Danny Richie
« Reply #3 on: 22 Oct 2020, 10:21 pm »
And the standard A370 amps are still being made.
