New Member NOT a DYI Yet But maybe with some help
0 Members and 1 Guest are viewing this topic. Read 578 times.
Claude C
« on: 13 Oct 2020, 04:28 am »
Hi I'm new here. Been watching  Speaker DYI repairs and up grades on Youtube and came here.  DYI on a speaker that I spent considerable coinage on scares me.  But I'm thinking I might get my feet wet if I knew how to safely get the front panel off my Polk S60 speakers without breaking something. I'm thinking if I could get access to the insides, lining the cabinet with "NoRes" might be an easy place to start.
Re: New Member NOT a DYI Yet But maybe with some help
« Reply #1 on: 13 Oct 2020, 01:03 pm »
Welcome!
First, the term is "Do It Yourself" or DIY.  If done right DIY can dollar-for-dollar match/exceed pre-manufactured gear (avoiding expensive machined faceplates for an example.  And of course you can customize your piece (upgrade capacitor or veneer for instance).
Second, suggest starting out with kits.  There are lots of good kits and advice out there.  CSS has some of the best loudspeaker kits for beginning DIYers.  Realize that a good assortment of quality tools will be needed to do good work.
Third, avoid designing anything.  There are professionals out there, not pretenders or glorified hobbyists, who do that for the living and are part of organizations with deep R&D/manufacturing histories making stuff that DIYers simple can't match.  Even adding No-Res is a crap shoot.
And above all, be wary of the "proud papa" syndrome where everything you do sounds good until it doesn't.  In some circumstances DIY can out perform pre-manufactured gear, but only under extreme conditions (use of exotic/uber expensive parts/materials, ultimate workmanship, so delicate/big/heavy it can't practically be shipped, etc.).
Phil A
« Reply #2 on: 13 Oct 2020, 01:40 pm »
Welcome!
« Reply #3 on: 13 Oct 2020, 03:54 pm »
Greetings & Welcome to AC Claude   :thumb:
« Reply #4 on: 13 Oct 2020, 10:47 pm »
Welcome Claude  :thumb:
