Philips 274 Rectifier tube
0 Members and 1 Guest are viewing this topic. Read 1861 times.
Manolo
  • Consulting Structural Engineer
« on: 11 Oct 2020, 08:42 pm »
Greetings! Today I got a stash of used tubes from a friend who inherited them. Among them, I found a Sylvania 5ar4 rectifier and various other rectifier tubes, including 2 labeled Philips 6909 274 which I presume are rectifiers, bur the designation does not have the suffix B, which is familiar to me for this rectifier. Its print says 6909 274.
I wonder if I can try these as rectifiers in my preamp. The Sy;vania is already working in my preamp.Thanks for looking!
Re: Philips 274 Rectifier tube
« Reply #1 on: 11 Oct 2020, 09:45 pm »
Not safe try vintage tubes in your valuable hi end pré amp, you will using your equip as tube tester.
These tubes are never used ?
After 6 mounths  the getter goes tô sleep.
Tom Bombadil
« Reply #2 on: 12 Oct 2020, 01:25 am »
Yes, 274B is a rectifier tube.
But a 6909 tube is definitely NOT a rectifier.  I don't know why it has both numbers on it.
Does it look something like this?
https://vacuumtubesinc.com/index.php/vacuum-tubes/6909.html
Manolo
« Reply #3 on: 12 Oct 2020, 10:48 am »
I will post a picture today. But it does not look like the one you posted. Thanks!
Manolo
Re: Philips 274 Rectifier tube - PICTURE
« Reply #4 on: 12 Oct 2020, 08:00 pm »
Here's a photo
« Reply #5 on: 12 Oct 2020, 08:24 pm »
This is not a 6909 tube, 6909 is a decatron tube.
https://www.radiomuseum.org/tubes/tube_6909.html
Looks a antecessor of the 274A / B IMO.
Manolo
Re: Philips 274 Rectifier tube another picture
« Reply #6 on: 12 Oct 2020, 08:53 pm »
one can see the interior stails better...
« Reply #7 on: 12 Oct 2020, 09:10 pm »
There is any date code in this tube?
If no 6909 may be the date code apparently.
Manolo
« Reply #8 on: 12 Oct 2020, 09:44 pm »
it looks like a 274B, five pins. No date, lettering in glass is completely erased.
