Bryston 4B cubed and Revel Salon 2
0 Members and 1 Guest are viewing this topic. Read 907 times.
Q.C.B.
« on: 29 Sep 2020, 03:29 am »
Has anyone tried Bryston 4B cubed with Revel Salon 2?
What have you thought about this combination?
Would it be enough only one in stereo mode or would I require a pair in mono?
  • The Demo is Everything!
    • http://www.bryston.com
Re: Bryston 4B cubed and Revel Salon 2
« Reply #1 on: 29 Sep 2020, 08:27 am »
Hi Q,
What is the nominal impedance of the Salon's? Also the efficiency?
james
GeAllan70
« Reply #2 on: 29 Sep 2020, 10:25 am »
Nominal Impedance   6 ohms (nominal) 3.7 ohms (minimum @ 90 Hz)
https://www.revelspeakers.com/products/types/floorstanding/Salon2-.html
 :popcorn:
Q.C.B.
« Reply #3 on: 30 Sep 2020, 03:23 am »
Thank you for your replies. The efficiency Appears to be of 86db, I forgot that Bryston works in mono at 8ohms, do you think there might be a problem by using it this way?
Or would it be better to use only one amplifier in stereo mode?
What do you think?
Thank you.
« Reply #4 on: 30 Sep 2020, 03:28 am »
What do you think?
Thank you.
Hi
When you bridge an amplifier it 'see's' 1/2 of the impedance it does in stereo so it is a concern to some degree if using speakers that are normally at 4 ohms or lower.
With the Salons I think you would be fine using the mono position but I usually recommend a larger stereo amp over bridged configuration.
james
