0 Members and 1 Guest are viewing this topic. Read 1446 times.
I've come full circle; from 2-channel to 5.1, now 2-channel again, and I'm never going back. Two-channel has coherent imaging and a purity that multi-channel just can't match, IMHO.
I wonder if the seemingly neverending One Box solution that many younger people chase after will end up bringing back solutions like the Radiogram ..not in terms of radio & tt in a box but rather a piece if funiture sufficiently wide enough to allow a proper separation of 2 non micro sized speakers and hence a 2 channel system will reside once again in the living rooms of the many
We're still in the experimental stages of multi-channel. Just look at the all the variations and formats out there. If done "right" multi-channel is superior to stereo, but that's a big "if". First the multi-channel design needs to be standardized, next the mixing is really complex and can easily be messed up, then you need the right speaker setup/designs for whatever that future format will be, and finally you need a big enough room to allow you and your's to sit in the middle away from all those speakers. Don't see the masses going for junking up their limited living spaces with hordes of loudspeakers.
