For Sale: Aerial Acoustics 10T MKII *SOLD*
0 Members and 1 Guest are viewing this topic. Read 1527 times.
Ledhead26
« on: 20 Sep 2020, 09:44 pm »
Here is a nice set of Aerial Acoustic 10T MKII speakers. One of the best speakers made in its time and they still hold their own against some of today’s better speakers.
I do have the boxes/packaging for these guys but would prefer local pickup. I am located in Maryland 21921. Shipping may work if someone is willing to set it up at their cost.
I’m asking $2000 or best offer and I may be interested in trades for like valued power amps.
Being a MKII, these have upgraded crossovers and the improved Novalith cast synthetic stone head material for the tweeter/midrange module, which does not have the hair-line cracking problem of the MKI experienced. The swiveling heads are in very nice condition with minimal scuffs as pictured. The bass cabinets are finished in the Rose Walnut veneer finish. Each speaker has a cosmetic repair to the veneer on one bottom corner. One is barely noticeable, and both are cosmetic only. This pair also comes with custom made stands, which are mounted on heavy duty furniture grade casters, which really help with positioning these speakers. They are bi-ampable, and come with top quality drivers.
Specs:
Description: Three-way, floor standing, dynamic loudspeaker with reflex-loaded bass cabinet and separate tweeter/midrange module. Drive-units: 1" titanium-dome tweeter, 5.3" (136mm) dual Kevlar/epoxy-laminated-cone midrange unit, and 10.7" (271mm) bilaminate composite-cone woofer. Crossover frequencies: 360Hz, 2.7kHz. Crossover slopes: fourth-order, 24dB/octave, acoustic Linkwitz-Riley. Frequency response: 28Hz-20kHz, -2dB, -6dB at 23 Hz. Sensitivity: 86dB/W/m (2.83V). Nominal impedance: 4 ohms, 3 ohms minimum. Amplifier requirements: 50W minimum, >100W recommended.
Dimensions: 41.5" H by 13.75" W by 19" D. Shipping weight: 190 lbs (shipped in three boxes).
https://www.stereophile.com/floorloudspeakers/466/index.html
« Last Edit: 26 Sep 2020, 06:31 pm by Ledhead26 »
rollo
  • Rollo Audio Consulting -
Re: For Sale: Aerial Acoustics 10T MKII
« Reply #1 on: 21 Sep 2020, 05:07 pm »
  One will not find a better speaker at 2K. Jump on this. good luck.
charles
